What is Vista doing on startup?
25 Apr 2004
Devon
I don't know if this is common to everyone, but when I boot into Vista, after the desktop has loaded the CPU usuage fluctuates from around 2%, up to 12% and sometimes higher to 18%, there is quite a lot of disk activity and under the 'Physical Memory' column in windows task manager, my 'Free' memory goes down and the 'Cached' memory goes up.
System has been on for 5 minutes now:
Total memory: 2045
Cached: 1679
Free: 53
At startup the cached would have been a lot lower and free much higher.. what exactly is going on with this?
After about 5 minutes it seems to be done, the cpu usage still fluctuates a bit but HD activity slows down or stops.
No process can be seen to take up these jumps in cpu, it literally goes from 2% to 12% and back in a second... uptime now is 1h 44mins and it's showing between 0 and 4% usage, no hd activity at all. Whatever it's doing it just seems to do it on startup! Free memory now at 16mb with 1681 cached
It's not the search indexer or anything is it? I know Macs were slow for a couple of days after going from 10.3 > 10.4 while Spotlight indexed everything.
it does some background tasks like defragments, cleanup, cache cleaning etc if you leave your machine alone after boot. Load up a program or whatever then close it again and you'll see its back to around 1/2% It's just done when your machine isn't in use.
i dont use search
one of the first things to get taken off of the start menu, and disabled.
Why use it, i have an excellent system for organising my files and so on. so have found no need for it.
Datamonkey said:
i dont use search
I use it for my Music folder mainly, just type in the name of the artist, and all of their music comes up. Could do it in media player I guess
turn things off that you dont need like the sidebar
also, i found disabling the constant file scanning that defender does will speed up your machine a bit
go into defnder, tools, options
disable realtime protection, and set a daily scan instead
FishThrower said:
people dont use search? :)
Again I don't use search - have never found is inecessary. For music, I use the search in iTunes, for other files I keep them in decent order. Even if I didn't, I don't have enough to make it worth searching.
While I'd agree I never used it in XP, it's pretty useful in Vista. Everything's instant, and the start menu search is fantastic. Hit start, type a few letters and it'll search through you start menu, favourites, history, files, emails, email attachments. Makes life so easy.
