Essentially fictional. It doesn't make your life any easier, just in some circumstances it can make it less difficult.
So not fictinal then?
Good to see you finally come around to the idea that it exists though![]()
Difficult and easy are antonyms so your second sentence is annoying.Essentially fictional. It doesn't make your life any easier, just in some circumstances it can make it less difficult.
3Taking bets on which (standard length) page this thread makes it to.
Having white privilege doesn't make your life easy, but understanding it can make you realise why some people's lives are harder than they should be.
I mean, that's literally the second quote mentioned in the article
Such a contradiction. How can it not make your life easier and yet make it easier is some circumstances? :S
When did I deny it?
I guess you can twist it around to mean it doesn't make your life easier than it should be, but prevents it from being harder than it should be?
unless you mean
"It doesn't make your life any easier, just in some circumstances it can make it less difficult than someone who isn't white"
