what is winxp mode within win7 ?
4 Feb 2003
telford, shropshire
hi,
just wondering what this is likely to affect, the current RC version runs everything i need to but i'm not sure what "version" of win7 its considered to be, so not sure if it contains winxp mode.
cheers........
"Windows XP mode" is a niche feature which requires you to download and install Microsoft's virtual machine software. You would know if you were using it. It's aimed at a small number of specialised buisness productivity applications that don't otherwise work in Windows 7. It's nothing to do with Windows 7 being compatible with the majority of existing Windows software.
