- 16 Nov 2011
Hey guys.
So i've been looking into upgrades recently, and it was only a year since i upgraded my Graphics card.
I was thinking either my CPU, which is a i7 2600 @ 3.4ghz or upgrading to a 780 3gb nvidia.
Mainly because i want to consistently hit above 90 fps to fully utilize my 120hz monitor, usually 60 to 75-80 fps feels sluggish when you've gone to 120hz
My case isnt huge, a zalman z9, but ive managed to squeeze it all in.
My CPU fan is still stock on my i7, so id upgrade the fan too if it did CPU, how easy is it to change a cpu, is it a case of remove, replace and download drivers like when you first build a PC?
RAM is fine,mmight need a PSU upgrade at 750w, but it seems fine as is, was thinking of one day making it 4k fully reliable, as i have a 4k monitor i just dont up it to 4k resolution and use it for side stuff.
Many thanks, my full specs are
i7 2600 @ 3.4ghz, nvidia 680 power edition, 8gb samsung green, and i dont remember the MOBO make but i know it'll take a new card or cpu, not sure if i have enough case space depedning on how much bigger the 780 is from the 680
Many thanks.
Many thanks.
