What is your go to chain lube and cleaning regime?
22 Aug 2010
On the Wagon-East Angular
Time to change the chain and sprockets on the GPZ500. I'm getting a DID VX3 chain and JT sprocket set from WeMoto and want to keep it in decent condition. I ride in all weather. What are your chain maintenance tips and what chain lube do you all recommend? I have an almost empty can of Yamalube platinum a mate gave me. I've also got a can of the MucOff chain cleaner and a u brush for cleaning I bought a little while ago.
Ta!
Hmmmm, I generally only clean my chain once a year I just use a toothbrush and fairy liquid.
For lube I use gear oil and an old paintbrush.
However, I'm one of those fair weather guys these days, and apparently gear oil isn't so great in wet conditions. So unfortunately what I do, may not work for you.
If you riding through winter I recommend an auto oiler, I also use paraffin to clean the chain, pretty cheap for a 5 l bottle and loads cheaper than the branded stuff.
I used to have a gpz500, nice bikes there was a couple of mods that made it run a lot better I think one was drilling a 1 inch hole in the air box but I can't remember the others.
I forgot to say if you want to oil it manually just get some chainsaw chain oil or gear oil works just as good as the branded stuff but loads cheaper
I use Halfords 80/90 Gear oil. It does get flung off much easier than specialist chain lubes so you need to keep on top of it. I generally lube it after every 3 or 4 rides. It's best done when you've come home after a ride and the chain is warm, I use a rag to get the accumulated dirt off the chain and oil the inside and outside of the plates.
I've never got on with auto oilers I've bought 2 bikes in the past with them fitted and they never worked properly so I took them off. A mate bought one for his bike and had nothing but grief with it and gave up in the end. If you're considering one I'd get it fitted by a decent workshop that will deal with any issues that crop up after fitting.
Gear oil here as well. Generally a quick squirt of WD40 chain cleaner when it needs a clean but to be honest as gear oil isn't horrible and sticky like most chain lubes it doesn't really hold a lot of muck so a quick wipe with some blue roll does the job most of the time.
I've pretty much always used paraffin to clean, then Wurth High Performance Dry Lube - never had any issues on any bikes.
Use paraffin as well, then Plutoline tech chain as it's the best I've used for not flinging the stuff everywhere.
I always lube when the chain is hot and leave overnight to set.
Mmmmmm, shaft........
Some helpful ideas and tips here, many thanks to all. I think I'll probably go with the gear oil idea for the new sprockets and chain, little and often. I tried applying with a toothbrush on the existing chain and it doesn't really take long at all!
Cheers all :)
