Anyone take a guess at what went wrong to kill the engine because i don't know.
It happened at low speed, approaching a junction, car stalled, PAS was lost (suggests bottom end was stationary to me)
Teeth stripped, that must've been the crank pulley?
Belt is only half the width it is meant to be, and has a groove in the back of it
that groove matches the damage on edge of the tensioner;
looks like it had been rubbing on something, but there was nothing there for it to hit. i couldnt get the tensioner to go anywhere near close enough to the head.
inlet manifold was full of water / oil
as was the pipework from the airbox to TB.
All 8 inlet valves are bent; (exhaust prolly are too, but not pulled the head yet - didnt have the right RIBE tool
had been driven for about 15mins before this happened and after the car stopped, it blew its coolant out the cap.
So what caused it, and what are the results of that. I can't work out which is which! (i know bent valves is cos the belt stripped, it didnt snap though). Engine is not siezed solid, and can be turned over with spanner on the respective pulleys.
