What kind of car does an electrician drive?
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
A Volts-wagon!
Anyway. Now I have your attention. I want to talk about the new upcoming PSUs from Antec.
They are called the EA Gold Pro. As you can guess they are 80 Plus Gold rated, they are semi modular and to boot are made by Seasonic, so are some of the best in terms of quality and performance.
We are offering a lovely 7 year warranty for peace of mind too.
There will be a 550w, a 650w and a 750w version.
With the exception of the 24 pin MBU connector all other cables will be the excellent flat style for easy cable management.
Here are the pics of the unit.
Below is the 750w spec data...
The only change other than the wattage is the 650w and 550w has 1 x 4+4pin only and 6 x sata connectors
The 550w also only has 2 x PCI-E connectors.
Are these based on a modified Seasonic Focus Plus Gold platform by any chance? Same dimensions and voltage distribution and the internals look similar too. If so these will be cracking units. Any idea of pricing yet?
That's aggressive pricing from Antec. The 550w could have done with being a bit cheaper as the 650w is only a fiver extra. Still, it's good to see decent psu's priced so competitively.
Funny you say that I told my HQ the 550w and 650w price was very close together as well.
Antec skimping on quality by going with Seasonic instead of Delta :D
Seriously though these look like good value units.
