What kind of spec do I need if...
19 Jul 2004
Shoreham by Sea
I don't want to bottleneck 2 x 260 GTX in SLI and have some room for upgrades later?
Currently I've got a Core 2 Q6600 with 4gb of DDR2 but this seems to limit me in Medal of Honor/BFBC2 and no doubt it won't help me in other games that I haven't noticed yet lol.
So what do you reckon? What do I need? Feel free to suggest an appropriate OCed bundle :D
I looked at this but wondered how suitable it would be: http://www.overclockers.co.uk/showproduct.php?prodid=BU-023-OB&groupid=43&catid=339&subcat=
For GTX 260 SLi, I think overclocking your Q6600 to 3.6GHz should be sufficient.
Anyway if I was you, i'd wait for the new intel chips on Jan 9th :P
I've seen a few posts saying that even overclocked Q6600 wouldn't be enough for CPU heavy games :/ I'm already overclocked slightly using the built in easy overclock crap. Overclocking by 20% seems to provide slightly unreliable results since it locks up occasionally :/ 15% seems to work ok but only gets me 2.75Ghz per core.
2.75GHz isn't enough. Overclock Q6600 to atleast 3GHz.
I still wanna upgrade though so bring those suggestions along lol :)
Think this setup has been my longest running one ever :|
Interesting, i find it hard to justify to myself upgrading from my Q6600 3ghz to an i5 or i7. I normally only find it worthwhile to jump a generation so i am waiting for sandy bridge for a good performance/feature jump from my q6600. What resolution do you play at? I dont often find me reaching CPU bottlenecks....
I wouldn't upgrade from the Q6600 yet - keep it running as long as you can, get your money's worth.
I wouldn't have thought the OP would have any issues with that spec - perhaps there's something else going on here.
Well I've had this cpu/mobo/ram for 2 years and whilst it has done alright considering I have gotten the urge to upgrade recently since I started to get more money again :P
According to http://www.cpubenchmark.net/common_cpus.html the performance difference between my Q6600 and something like an I5 750 is quite considerable!
I'm not against waiting for the new technology to come out if its just around the corner though so I can wait a little bit :)
As for the res and reason why I think a CPU upgrade is necessary - The main example is MoH multiplayer. The SLI visual indicator barely shows more than 1/3 if the gfx settings are low/medium. Its only when I crank the settings to high when I start to see SLI usage to get near full. From what I've read people with meatier CPUs get more usage/scaling where as even people with Q6600 chips clocked at 3.6Ghz don't get much boost in performance :/
Guess ultimately I just want a suggest of some decent parts to through together since I haven't really kept up to date with any of the latest hardware for a good few years :P This kit was kinda chosen for me since I could get it cheap lol
Yes but while doing that, do you see an increase in frame rates? Or do they remain static. If they are static then it means from low->high your cpu is bottlenecking you. And anyways, I've got an i7 to 3.885ghz and i doubt is using much cause temps are at load at around 58-63 and while stressing they jump up to 85 (both with heater on).
As people said, since you are upgrading soon, and it is more "profitable" to be later (due to new launches and due to getting more performance for money given on current rig) try take your system to the edge.
Eventually, if temps are an issue, get a cooler both compatible with the socket you might upgrade and with current socket so you can clock your CPU as high as possible. Your cpu should be plentiful at least until Sandybridge launches and prices find their way down again.
On the other hand, if the money's burning a hole in your pocket why not go for it? I upgraded from a Q8400 @ 3.1 GHz to an i5 750 @ 4GGz over Christmas, and I'm enjoying a much snappier feeling computer. Frame rates seem smoother, if not higher in most games, and Empire TW, and GTAIV have had a major boost.
