What kits next for my canon 20d
Permabanned
22 Sep 2003
ok guys got a little extra cash o i want to had to my kit any ideas what i should get at the min i hve
canon 20d
1 batt
1 2gb memory card
50mm 1.8 lens
70-200 f4 l lens
28-300 tamron should be saleing this soon
good bag
should get getting a 17-40 l before the week end
so what else do i need ?
i`d get a tripod or monopod (or both), a couple of cheap spare batteries, spare mem card, remote switch, grey/whitebalance card , good flash gun , macro lens?
it really all depends on what you want to take piccies of i s`pose
canon 20d
1 batt
1 2gb memory card
50mm 1.8 lens
70-200 f4 l lens
good bag
Some top notch filters should be on your list.
Flash gun.
Grip
Fstop11 said:
Ooh, forgot about that one.
I wouldn't be caught dead without the grip for my 350d, it's a godsend. Not sure how big a difference it'll make on the 20 because of its size, but it's made the 350 a whole different camera. :D
It makes all the differnce with any camera. However sometimes I like using the 20d without it. due to its natural SLR feel.
I'd probably say something in the 10-20+ range, that seems to be where your lacking most at the moment (however if you dont shoot wide stuff I guess you can live without it).
difficult to recommend something without really knowing what you shoot. If it's just buying something because you can, get whatever takes your fancy.
There's a few things which could be appropriate. Swap the 70-200 F4 for a F2.8 version, grip, extra batteries, extra cards, portable storage, macro lens, tripod, new bag, sensor cleaner, teleconverter, long prime etc.
busterboy said:
Canon 135mm f/2L
The most used lens in my kit.. ;)
busterboy...the first time i've heard of the 135 f2 mentioned on here. I am interested in picking up this lens...do you have any sample shots you took with the lens? also how fast/heavy/bulky do you find it?
