SDK^ said:Your missing a wide angle lens from your current range - how about a 17-40L F4
Marik said:buy them all.
The only drawback with the 16-35L is the price, unless you go via the HK routebusterboy said:The 17-40mm is a very good buy but if you fancy L glass and spending some more look at the 16-35mmL
SDK^ said:The only drawback with the 16-35L is the price, unless you go via the HK route![]()
