Other than core voltage what limits how high you can up a multiplier?
I'm currently struggling to get my 5000+ Black Edition higher than 3.1GHz @ 200 - 15.5x.
I've stuck up the core v's to 3.75 (AMD overdrive won't go any higher)
and my new MSI K9A2 for some reason has volts lockd in Bios.
Could it simply be that my cpu chip can't go any higher?
My temps are awesome so that aint the problem.
Thanks for any help in advance.
and my new MSI K9A2 for some reason has volts lockd in Bios.Could it simply be that my cpu chip can't go any higher?
, 1.55v Max safe with Good Air Cooling, 1.6v with high end Air Cooling
