adelburn said:Cheers for that.
Am I right in thinking that cache size is Virtually irelevant unless using CPU intensive programs, or hardcore gaming and that most "normal" users will be ok with 1mb of cache.
Also, bit of a noob question, but what are the bonuses of having a faster clock speed or FSB. Basically what I am trying to say is would it be more beneficial saving on the CPU and spending more on a HDD with a faster access time to increase performance?
clocka said:the cache size, socket, overclockability, clock speed and fsb.
the e6750 is the best non-expensive core2duo cpu and the q6600/6600pro is the best non-expensive quad core cpu.
the e2140 is very cheap and will overclock to 3ghz nicely, so those are the 3 best price/performance cpu's at the moment, depends on your budget and whether you will overclock to which cpu you buy.
BlastRadius said:In the case of a faster HDD or faster CPU I guess the CPU takes it everytime. I noticed very little difference when I had 2 150G raptors but when I overclocked my C2D OMG did that ever make a difference!
The trick is to strike a balance between all aspects of your PC so that one component isn't bottlenecked by another. No point having an Extreme quad core for gaming using an Nvidia 6200 turbocache for example.
adelburn said:Am I right in thinking that cache size is Virtually irelevant unless using CPU intensive programs, or hardcore gaming and that most "normal" users will be ok with 1mb of cache.
jaykay said:FSB kinda Intel know its getting old and are going to use AMD's Hypertransport with the Nehlem cores i think.
helmutcheese said:Very strange as the HDD is the modern PC's bottleneck.![]()
