What Manfrotto Tripod and Head
Ive got 055Pro legs and a 488RC04 ball head. The ball head has independant pan and the largest quick release plate.
Not light, but built to withstand just about any thing.
Depends what you want from it? Are you after a lightweight one, a heavy studio one? One that can go really low? I recently went for the Manfrotto 190XProB Tripod with a 322RC2 head. This combo offered the features I wanted; relatively lightweight and very low minimum height. So far im very pleased with it. See my thread for more details;
http://forums.overclockers.co.uk/showthread.php?t=17725241
if its an everyday out and about tripod i give a vote for th 190xproB top piece of kit not too heavy to carry about. mine has an 804RC2 3 way head not let me down once yet! and got all for £140
Defo get a PRO model, you'll regret it otherwise as the other don't go so low (the center column doesn't mount horizontally).
I have the 055PROB and I've never found the weight to be an issue myself. I went on a 4 mile walk with it not long ago and found it fine, and I've even ridden my bike with it round my neck (not a good idea).
Just to save a fresh thread; can anyone post some advice about buying a head?
Specifically the pros and cons of a 3-way Vs a ball joint head?
Thanks
Panzer
*Bump*
I would like to know the same thing as Panzerbjorn.
After deciding on the ultra luxi F tripod it now seems to be sold out :rolleyes: . I have decided to spend way more money than I should and get a Manfrotto tripod and head instead. I think I am decided on the tripod (the 190xproB) but have no clue on heads. :confused:
Also I am 6'2, would I have issues with the 190 being too small?
Im 6'1" and a bit (or something like that), and the 190XProB is just about the right height for me standing up with the legs fully extended and the centre column fully extended. Having the centre column fully extended is not ideal as it reduced the stability somewhat, but if your only going to be using it at that height from time to time then its fine. I tend to do much lower down work, which is one of the reasons I went with the 190XProB, as I can get right down to the ground with it. If your going to be using the height more, then you'd be well worth looking at the 055Pro as well, as its essentially the same as the 190XProB exept it goes taller, and weighs a little more.
extend my 055 to max height and to the top of the quick release plate on the 488 it's 6' 2". Plenty tall enough for me.
Thanks
Panzer
I'd be interested in this too.
Quick Google came up with
Construction Material:
The carbon-fiber tripod offers the greatest weight to stability ratio against the more common aluminum tripod. The carbon-fiber model will also be easier to hold during those cold, winter days. Unfortunately, the carbon-fiber tripod will come with a much higher price tag. If you can afford the price tag, it is an item that you won't be replacing and won't regret using. If you cost average the price against how many years you will be using it, it might become the one to think about after you realize all the compromises that you had to consider on similar models. If you end up replacing a tripod that didn't fit your needs, the extra cost of eventually purchasing another tripod might cost you the same price.
Tripod Height:
There are 3 heights that you should be concerned with:
1) The maximum height
2) The minimum height
3) The folded height (figure 2 #2).
You have 2 options regarding the maximum height. The tripod with camera can be at eye level to you Tripod Photography © Outdoor Eyesor the tripod and camera combination can be less than eye level. The tripod that is less than eye level is generally referred to as mini or compact tripod. The tripod that is less than eye level is generally lighter as long as equal construction materials are compared against one another. This tripod tends to fold up into a shorter unit for carrying or packing. You will generally regret choosing a shorter model as you will constantly be bending over or lowering your body to photograph. Do not get confused and add the height of the centerpost into the height of the tripod as it is meant for minor adjustments, and when raised too high, it tends to make the tripod less stable. Usually the choice of a shorter tripod is considered when weight and cost becomes a factor. Obviously, with a lightweight carbon fiber construction, the weight decreases and the price increases. The tripod that is right for you is the one that does not stay at home due to the tripod's weight or the size.
Centerpost:
There are 2 options available for the centerpost:
1) smoothed
2) geared.
The smooth centerpost is extended by holding the centerpost and raising it. The geared version has a small crank on the side, and when turned, raises or lowers the centerpost. The geared version allows you to raise or lower the tripod with one hand which is for some, and advantage. There is also an option with the smooth centerpost. Some manufacturers allow the centerpost to be removed and turned upside down so that the camera can be closer to the ground... upside down. This feature comes in handy some times. If you feel that this might be of value, then consider the smooth centerpost.
Legs:
There are two choices of type of tripod legs:
1) tubular
2) channels.
Tubular models are almost always heavier, resulting in a longer life span and a more stable support. The legs usually have 2, 3, 4 or 5 sections. The tripod becomes less stable with more sections added while the tripod's folded height becomes much shorter. The sections of the legs are adjusted by means of a leg brace, the more common types being either a flip-lock or clamp lever (figure2 #3) or the threaded twist lock (figure2 #1). Threaded twist locks offer good strength and rigidity, but take longer set-up and breakdown time. They are also subject to over tightening and can pick up sand and grit. Flip-lock or clamp levers are generally the most satisfactory overall because of quick set-up, trouble-free operation (easy to use with gloves), and long term durability. The type of locking device is usually a personal decision since there are many pros and cons for each type of locking device.
Feet:
The tripod might have a combination of two types of feet:
1) outdoor use
2) indoor use.
Some tripods allow you to unscrew the bottom of the legs to produce a pointed end for outdoor use. When the feet are set to normal, the legs have a rubber bottom for indoor use.
Head:
Check the specifications on the maximum weight that the head can handle to make sure that it will work Tripod Digital Photography © Outdoor Eyesproperly with the tripod since the choice of head is even more important than the tripod choice. Also be sure to check the maximum weight that the tripod and head in combination can handle. Pan-tilt heads are excellent for landscape and macro work. There are 2 types of pan-and-tilt heads (figure2 #4):
1) Two handle
2) One handle
The single handle head was originally for movie and video cameras that required horizontal positioning only. The two handle head has the ability to adjust both horizontal and vertically so that you can position your camera at the exact position necessary. They also make good general purpose heads.
The other choice is the ball head (figure2 #5). Frequently, ball heads are used for bird and wildlife photography. A ball head will perform well under these shooting conditions where photographers sometimes leave the controls slightly loose with the friction set just tight enough to hold the camera steady, but loose enough to make smooth adjustments to moving subjects. This allows unprecedented ease of following a rapidly moving target. Some manufacturers also have "tensioning" devices to control the ease with which the ball can be rotated. This is desirable as once the weight of your camera/lens combination increases it can be awkward if the ball is completely loose. The bigger the ball, the more likely it will be to behave this way. Check the diameter of the top of the tripod to make sure that the ball head will fit properly on top of the tripod. Some heads have a larger diameter and overlap the top of the tripod. If in doubt of your choice, check with the manufacturer of the tripod or numerous retail stores to receive advice.
A common mistake is to not allow enough room for your lens to clear the platform on the tripod. Be sure that your all the lens that you own or intend to purchase will not interfere with the extended platform. The lens may not be able to be adjusted to all positions. A platform that is about 2x2 or 2x3 should work properly. Test this out in advance before purchasing a tripod. I believe that the head, camera and tripod should be tested as a complete unit before a purchasing decision is made. It has been my experience that this is the only way to prove the utility of the tripod and head with the actual camera(s) being used. I think you would be surprised that some systems that you think are "solid" with one camera system, are wobbly with another.
The quick-release system should be added to your tripod. This allows you to quickly and efficiently remove or mount your camera on your tripod.
Stability Test:
If possible, mount your camera on the tripod that you are considering. Stomp on the ground next to your tripod and watch the camera lens move. Then, jiggle the leg of the tripod and watch the camera lens. You are looking for the least amount of lens movement and the quickest recovery (how long does it take the lens to stop jiggling). The smaller or lighter the tripod, the harder it will stand up to this stability test.
http://www.outdooreyes.com/photo11.php3
On my 190XProb with Mag head and the column unextended I have to stoop a little to look through the cameras viewfinder. The tripod (unextended) with head and camera comes to about 1.6m. The 190xprob is fairly lightweight but very well made and put together. I'm happy with it but if I was to buy again I think I would go for the slightly higher 055 simply because I then wouldn't have to stoop otherwise the 190XProB is an excellent choice, oh and I'm 5ft 10inch...
The issue I have is that the 190xProB is already over my budget so the 055 is even more so. Its also heavier and the extra 3 or so inches when folded up I think will make a real difference in the carrying difficulty. :(
