What media centre case
23 Aug 2006
North Wales
Hi i am building a media centre pc using my old pc parts but i dont know what to case to put it all in. I dont want to spend more than £60 on one if i can help it and it needs to support full atx motherboard and have enough room for a ati 4870 graphics card. If need be i will just get a normal pc tower but i would really like a media case if i can.
So if anyone can advise me on a case i will be most greatful.
Thanks.
the only case i can think of in that price range from ocuk that might be suitable woud be this - http://www.overclockers.co.uk/showproduct.php?prodid=ca-189-cm&groupid=701&catid=7&subcat=29
although it is a tower the drives fit in a way that it can be sat horizontally like a desktop or media centre case (the coolermaster badge even swivels round so it doesn't look like its sitting the wrong way :)) and it fits atx boards but i'm not sure if it will take a 4870 though.
found a review of it here - http://www.motherboards.org/reviews/hardware/1890_1.html
hope this helps :)
