What memory do I need to go with this:
https://www.overclockers.co.uk/showproduct.php?prodid=BU-005-GI
I wont be overclocking - what speeds does the CPU/motherboard/ram run at?
The cpu information says:
Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
The motherboard says:
4 x DDR3 DIMMs 1066/ 1333/ 1600/ 1866(OC)/ 2133(OC)/2400(OC)/ 2666(OC)/ 2800(OC)/ 3000(OC) up to 32GB max
So is that 1600 the default, non-overclocked speed?
Is there any advantage to higher speed memory if the CPU/motherboard is at 1600?
As you can probably tell, I'm not particularly knowledgeable on this
I'd quite like 16GB, so any recommendations on what to buy would be good too.
Thanks!
Thanks!
