What memory for a IB ITX build?
10 Jul 2006
I am building a IB setup based around the 3570K and a mini-ITX motherboard and wanted to know what RAM I should get?
- I need 8GB (2 x 4GB).
- I will not be overclocking the CPU (underclocking it if anything).
- Max budget of £50.
I am just looking for the max speed RAM supported by the CPU. So don't want any extra gubbins unless it makes it faster or uses lower power/more efficient <--- I hope that statement makes sense.
I am buying now as I will be building when the IB motherboards come out and puttting a SB cpu in there until the IB cpus are released.
Thanks.
Agree with beejjacobs, but the deals will end tomorrow first thing and they might put the Kinngston on offer :D
Well, that is very nice RAM and I'd get some if I could, but what is the build for? In most situations [i.e. except benchmarks] you won't notice a difference!
For a development machine. I'm building some software which is very CPU/memory intensive at the moment...would I notice the difference?
I'm trying to gauge whether its worth it.
Also - what if I went second hand? Or is memory at that price where the new price is close to the second hand price?
EDIT: Also, what would you the power draw difference be aswell?
Someone else might know better, but it sounds like you might notice a difference then yes. It's great RAM, if its in budget go for it!
I wouldn't bother second hand for RAM, just because it is so cheap!
Have you seen this thread about the Samsung Green?
http://forums.overclockers.co.uk/showthread.php?t=18379546
Power draw of RAM is probably very low, but this Samsung does/can run at very low voltages which is always good!
Probably what you recommended.
Something has just occurred to me. My build will be on a mini-ITX board....could I run into problems with the cooler taking up the space that ram should be in...is that heard of?
Yes, but with low profile RAM - which both kits are that I've mentioned - that wont be a problem :)
