Im considering whether to buy the 800mhz ram, I believe this is a lot faster than the E6300 is initially set at. Is it quite common to be able to overclock the CPU to 800MHZ as I have heard it normally runs at only 533MHZ. Also would this produce a lot of heat as I was going to use the Ninja cooling device so I could run it without a fan.
this stuff rocks!
Thanks for all the advice though, it has helped a lot.
