What mob should I get?
18 Oct 2002
Brighton
Hi,
My requirements are prob different to most, & I don't really keep up on the new models etc hence this post...
I need a small/slim phone with bluetooth & simple to use menu's (e.g. Nokia), & that is it!
I don't care whether it's got a camera or mp3 etc as I'll hardly use them - I just want something that's VERY small & VERY slim with bluetooth.
I quite like the clamshell sliding designs, so maybe a Samsung D900?
Is there anything else that's similar that doesn't have all the 'bloatware' on?
Thx
That's not a great attitude to be taking, people don't have to make suggestions, people may not know what to suggest for you.
Pearcy said:
Hi,
Thx
Samsung P300 or X820.
The D900 is a very nice phone, i'd probably get that, or the X820 (i think that's the one that's really thin isn't it?) :)
Heh, sounds like you're the one with the attitute!, all I was doing was asking for some suggestions, & then bumping it up to the top.
After all, a forum is supposed to be an open environment for people to share their expecience & opinions.
I had the Samsung X820 but found it really uncomfortable when trying to text. I thought it was difficult to press the nearest buttons to my hand due to it being so thin.....if you known what I mean. Plus when it's in a pocket I can't feel it there so was always checking if it hadn't fallen out or been nicked.
Swapped it for a Nokia 6233 which I think is a lot better overall.
