What mobo is a overclockers wet dream under £200 ?
Permabanned
26 Jan 2009
I was just thinking of going 775 mobo but i7 Mobo`s arnt priced to far behind them.
Any way All I am after is crossfire and something that is amazing at overclocking for under £200 maybe a little more
Thanks !!
Hmm for a 775 I wouldn't be buying a £200 mobo... seems like a waste considering there are MANY ones around £100 that OC like the shizzle. £200 is good X58 territory...
Yup, spending £200 on a socket 775 mobo is way over the top, but then spending £200 on an i7 mobo isn't going to buy a jizzable board either.
the OP already has the chip otherwise I would have steered him towards the X58.
the Asus is a very capable board mate
Just make sure if you go for a P6T Deluxe you DON'T get the new V2 release as it is the same as the V1 but with bits removed to save costs. NOT an upgrade in any way shape or form :)
Notice the Asus P5Q Deluxe Intel P45 says it runs crossfire at 8x speed, does that mean 2x 4870x2 will run they are meant to in cossfire ?
8x pci-e slots are not a good idea for a pair of X2's. The 8x lanes will strangle them. You want a X38/X48 chipset board for full speed pci-e lanes. My old Asus P5E got a Q6600 to 3.8Ghz easily. My current DFI seem's to be a good clocker too from what i have tried so far.
