what mobo to get..
3 Sep 2007
Hi guys nd gals
im new to this computer stuff so please excuse me if my question seems stupid...
i have decided to go for a intel core 2 duo e6600 and am not sure what mobo to get...either a asus or gigabyte...
i dnt rele hav a tight budget but nufin ova £200
can you guys help please....would be very much appreciated
If you don't need RAID, firewire etc. you can happily get something like an IP35-E or P35-DS3 for under £100.
Don't scrimp on your PSU though.
If you're not overclocking, then £ for £ the fastest AMD CPU's are currently quicker than the Intels. The Intels clock up by about 50% which is why they are so sought after.
AMD 6000
http://www.overclockers.co.uk/showproduct.php?prodid=MB-016-AK&groupid=701&catid=5&subcat=808
and
Nice cheap motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=CP-195-AM&groupid=701&catid=6&subcat=803
with
You need a good quiet cooler!
http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-AR&groupid=701&catid=57&subcat=821
will get you a faster system straight out of the box than the Intel systems. And cheaper too.
If you really just want a fast-ish Intel system then;
E6750
coupled with a nice cooler and 650i Ultra motherboard will give you very good performance at stock and the overclocking instructions are here (about half-way down the thread).
Either system needs good RAM to perform at it's best and the OcUK Value stuff is superb value at the moment.
Either way, you'll get a stonkingly fast system at stock. Enjoy.
but why would u buy an e6600 now unless u are getting it 2nd and
perhaps because very few apps can use a quad or because it has a higher multi than equivalently priced 1333fsb C2D?
2nd hand makes a lot more sense though.
ok e6750 it is den as its cheaper nd faster..hav decided to get OCZ 2GB, PC2-8500 1066MHz SLI-Ready Edition Dual Channel DDR2 and finkin of this mobo Gigabyte GA_P35C_DS3R...
Also, if buying new, why get an e6600 when an e6750 is cheaper but faster?
got 1 less multi though so you have to run higher fsb to get a given clock -
comparable 1066fsb CPU is really the E6420 with it's 8x multi but which is slightly cheaper again.
The E6600 has a speed of 2.4GHz, which is achieved by FSB of 266MHz and Multiplier of 9 - 266*9 = 2394MHz - 2.4GHz
A chip with a lower multiplier (eg 8) will require a greater increase in FSB to achieve a given overall speed......so to get 2.4GHz with an 8x Multiplier one would need to have a FSB of 300MHz.
Initial C2D CPUs had a 1066MHz (quadpumped = 4*266MHz) bus.....newer CPUs (Exx50) have 1333MHz (4*333MHz) bus........so.......that's the maths over :)
In essence, when overclocking most CPUs, you raise the FSB.......motherboards tend to have a finite range of acceptable adjustment, as do the CPUs plugged into them........a higher multiplier on a CPU will make it easier to quickly raise the speed as each incremental adjustment is actually multiplied by said multiplier !
I can never make my mind up. One minute its the gigabyte and the next its the Abit.....
Which one IS the best you experts reckon ???
Steve
Go for gigabyte - their current P35 boards just work, no hassle, very few problems and overclock nicely... as a previous DFI/Asus fan I find myself somewhat bemused to be reccomending them but their P35 boards are simply a way smoother and pleasing experience than I've ever had with either of those 2.
& you can say exactly the same of the abit - they are both good P35 ranges.
So, it's down to features/bundle/price or any specific requirements or preferences.
If it helps, I'm a bit of an overclocking noob, but I just doubled the speed of my E2140 on the P35C DS3R Gigabyte board.
The thing practically overclocks itself :)
No.
The IP35-E & IP35 exhibited a double boot behaviour on cold boot (it's inherent to the chipset as the straps initialise & is normally hidden by some BIOS work) but a new beta BIOS has fixed it.
The IP35 Pro never showed it.
ah ok, cheers.
still unsure which to get!
abit ip35 or Gigabyte GA_P35C_DS3R or Gigabyte GA_P35_DS3R worried about the lack of cooling on the gigabyte.
