Also look at the Gigabyte S3. It is the same board as the DS3, but it does not have solid capacitors. The D in DS stands for durability apparently and the S3 will last about 3 years in normal use while the DS3 will last another 2 or 3 years beyond that. If (like me) you tend to change motherboards every few months, you may as well get the S3 as otherwise it's exactly the same as the DS3. And it's £20 cheaper too.
