What motherboard should i get??
15 Jan 2007
Hello all i wonder if you could give me some advice on a new motherboard and memory so my CPU and GPU can maximize there performance my current setup is in my sig.
I would also say that price isnt an issue.
Kind Regards
Tab
Would you like a motherboard that does Crossfire/SLi or is a single card all your interested in?
Have you tried increasing the CPU multiplier at all on your current setup?
Do you have a aftermarket heatsink?
I just have a question regarding Motherboards and Ram .. when u look at a MB specs and it states what ram it takes does the (O.C.) mean Overclock? sorry i dont mean to sound stupid ill post an example :
- Memory: 4 x DIMM, max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 MHz, ....
Its a setting in the BIOS, the slower figures are supported by the CPU's memory controller, the 1800 and higher will require manually setting this speed in the BIOS to what ever is printed on the side of the sticks on the label, same goes for the timings and voltage.
Actually the memory controller supports upto 1333MHz, thought something looked wrong.
You would either enter the higher values by typing in 1800Mhz or use dividers to get the 1800/2000 etc.
200MHZ X 8 = 1600Mhz
200MHZ X 9 = 1800Mhz
