What motherboard?
28 Jun 2007
Hi all!
Speccing a new system today and was looking for some advice/opinions as to which mobo to buy!
Looking at getting the following:
OCZ 2GB (2 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2 £135.11
Noctua NC-U6 Dual Heatpipe Northbridge Cooler £16.44
Tuniq Tower 120 CPU Cooler (Socket 478/754/939/940/AM2/LGA775) 31.71
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail £129.24
Ideally I want a motherboard that will allow me to get the maximum overclock..
I was looking at either the
EVGA nForce 680i SLi (Socket 775) PCI-Express DDR2 Motherboard (122-CK-NF68-A1)
or
Gigabyte GA_P35_DQ6 (Socket 775) PCI-Express DDR2 Motherboard
The only thing that gives me pause about going for a P35 chipset is the lack of SLI, I do game @ 1920x1200 with an 8800 GTX. However I don't forsee a need to get another one for a good 6 months at least.
If anyone has any thoughts/suggestions or anything else I should consider I would be grateful!
Thanks,
Rob.
I would change a few things their to be honest, something like this would be good:
Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB)
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit
Total : £405.62
Their you go, get a nice Quad Core in their too. Should reach 3GHZ with little problems.
You dont need 8500 Memory to be honest, bit of a overkill especially when something like the Crucial Ballistix will hit them speeds.
Right SLI is a waste at this point in time, unless your gaming on a 30inch+ screen, the performance you get out of SLI dosent really justify the cost of buying that second card.
And Welcome To The Forums. :)
i just ordered
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) - £59.99
Gigabyte GA_P35_DQ6 (Socket 775) PCI-Express DDR2 Motherboard - £119.99
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail - £109.99
Scythe Infinity Heatpipe CPU Cooler (Socket 478/754/939/940/AM2/LGA755) - £24.99
Arctic Cooling MX-1 Thermal Compound - £3.99
i will let u know how it goes but it cost me just under £400
Dont go Quad yet, theres not exact need for it so wait for prices to drop!
Thanks for the replies so far guys.
Still not decied on which mobo to get :>
I don't need a quad core as all I do is game pretty much.
Anyone know when the X38 will be out?
