- 7 Nov 2002
- Glasgow / Canberra
looking for a 40Gb MP3 player, what you suggest, or recommend ?
ta
ta
TooNice said:Umm, 40GB is a fairly unusual number. I believe some of the 4G iPod were that size, but nowadays it's either 30GB or 60GB (well, there are both smaller and bigger respectively, but around the range you are looking for).
If the player need to be 40GB or more, then I would narrow it down to the 5G iPod and the iAudio X5 (you can also find larger Archos, but they are really meant to be movie players).
If you don't mind 30GB, then you can throw Creative M:Vision to the list. Those are the three portable players I would consider today.
