What new Air Cooler?
27 Mar 2016
Bristolian living in Swindon
Hi all
So I'm on the hunt for a new CPU cooler as the stock Ryzen is not all that... I have a budget upto £50, what should I consider?
Doesnt need to be all bling RGB?
Must be upto £50 no more or I may get shouted at by the missus for buying this side of Christmas :p
Cheers
Off top of my head Fuma 2 would be my suggestion, but really need to know case, RAM and motherboard of system to know if it will fit. Maybe it's your sig rig, but because users sig rig data is often not kept current so have to ask. ;)
I just bought a scythe fuma 2. Installed it yesterday on my new build and it was quite easy and feels decent. I have nothing to compare temps with as it's a brand new build. Plenty of high praise from all over the web and youtube vids. I bought it here on ocuk for £50 exact with the free postage we get. Otherwise arctic freezer 34 eSports duo or non duo is a budget favourite.
I've seen barely used Noctua NH-D15's go for around that in the MM if that comes up as an option.
