What nVidia GPU driver and overclocking program are you using for your 7900 GTO?
How about GPU drivers, does everyone use the official nVidia ones, or are there third party drivers people use?
Im using the latest nvidia drivers but im not so sure about the new look control panel - what does everybody else think?
Im using coolbits to overclock. I got the memory upto 800 and GPU 685 to but im thinking of now using rivatuner to push the memory that little bit farther.
How do people nowadays check for stability with their incremental overclocks?
I used to run the latest 3Dmark and if there wasn't any artifacts i'd increment upwards till there were artifacts.
Then I would go down by 10MHz to find safest OC'ing level.
CoolBits here, Used it to find optimal settings which were 717/784. But I upped the memory to 800. Works perfectly ;) Really impressed with the Nvidia GTO Cooler.
I really like the old control panel, Aways found it to be nice and quick and just easy to use. It was nice coming back to it after my X1800XT. I found the ATi panel to be really slow.
Use the same method here, keep upping it, but normally up it 10mhz at a time to start of with.
