What on earth is wrong with this PC
27 Sep 2012
Hey folks,
Right I'm wondering if someone could please shed some light. We've spent many hours researching online and trying lots of different things.
Basically my house mates PC wouldn't boot. When we turn the PC on it just kept restarting after a few seconds of loading, and repeating that process. After 20 mins or so it would finally boot properly and manage to load into windows. The PC had absolutely no problems at all post bios, and never restarted once in Windows.
We then naturally tried the common things such as removing RAM, GPU etc. Even with nothing plugged into the motherboard it was still the same.
We then went out and bought a new PSU. However, the same problem occurs. Finally it must be the motherboard, so we've just gone out and got a new motherboard... same issue!
What on earth could it be? We've even tried my processor in his PC and it's the same issue. We have absolutely nothing plugged in to the new motherboard and it's doing the same. Just restarting over and over.
Is it possible that his CPU could be breaking motherboards or something? We've honestly ran out of all ideas.
Any help or suggestions would be great
Have you tested running the motherboard outside of the case to see if it makes any difference? There's maybe a short somewhere.
Yeah we've tried all those options too.
The only thing I can think of is his old PSU is breaking the other motherboards? After we tried a new PSU and it still did it we took it back. So I'm wondering if it's his old PSU breaking stuff
If whats being said is accurate it must be the wall socket.
Different mobo with different CPU with different PSU, different memory all outside the case "with nothing plugged in" "not even any drives" then its an entirely different PC.
Edit: Is the CPU cooler being attached properly? The default 90deg leg twist stock coolers can catch people out. Would cause the restart symptoms as described.
Did it ever work properly? IE is it some sort of incompatibility?
Which leads me onto : Mainboard Firmware?
The fact "Once warm it gets into windows" totally sounds like a power issue.
how new is it?
Thanks for the reply guys.
So we went out and bought another brand new PSU, motherboard and RAM. We left the motherboard outside of the case and plugged in the RAM and PSU. Also connected the cooler fan...
Same problem!! I've tried it on different plugs in the house and surge protected ones etc. Bear in mind my other house mates PC is next to his and fires up fine. So does mine upstairs too. Also there's absolutely no other electrical problems with anything else in the house.
Is it possible that a single plug socket is just killing his stuff? Even though other electrical stuff plugged into it works fine?
WTFBBQ
If there is a wiring fault, then resetting the breaker might not have much effect. A socket tester will tell you for sure if you have an issue. You could have any of a number of possible faults as per page 2 of my tester's instructions:
http://www.kewtechcorp.com/sites/de..._manuals/Kewcheck 103 Instruction leaflet.pdf
If too many things are connected to one socket, you might also be overloading the socket.
I have a friend who's 4790K suddenly started lunching motherboards. We reckon at some point something damaged the CPU.
It is also a 4790k but still did the same with no CPU installed at all
Is there a speaker on the motherboard, or can you plug one in? Does the motherboard make any beeps, or if there anything on the board showing status codes?
It could be resetting due to getting abnormal readings from fans, voltages or anything. Does it reboot at the same point or does it vary? Are you using the same disk and build - perhaps try a boot CD/USB stick?
Surprised the board would boot at all with no CPU in? (unless I misread that bit)
If you can get into the bios settings, check what there is for cpu and memory speeds and the like. If everything is on "AUTO" settings this can make some boards reboot several times until it finds the correct working settings, especially if there is a hardware issue somewhere.
