WHAT OPTERON TO GET?
20 Nov 2004
UK
Hi what opteron would you advise getting? choices between 160, 165, 170, 175?
What do each of these usually overclock?
IS THE 165 BASICALLY A DOWNCLOCKED 4400?
ta :)
Sort of, it is the same core, same cache and usually overclocks to the 4400+s 2.2 Ghz (and beyond) without breaking a sweat.
165: 1.8 Ghz (no equiv)
170: 2.0 Ghz (X2 4000+)
175: 2.2 Ghz (X2 4400+)
180: 2.4 Ghz (X2 4800+)
185: 2.6 Ghz (FX-60)
If you have a good/high fsb motherboard might as well get the 165, check the stepping/week out before you buy.
Hi
Thanks for the info kno nuffin bout opterons. :)
My mobo can doo 300*9 fine, and it looks like most 165's can do this aswell.
Might go for the 170 though, means I could do 300*10 :)
BTW saw the 165 @ 104inc vat :O (thats good aint it? And ive seen 3800+'s for 75inc vat) All brand new!
You can even get a 185 new for 200sh but trouble is that Core 2 Duo makes them all look iffy value. I'd try get a cheap, high clocking one from an upgrader rather than pay full whack, cos lets be honest, how long are you gonna keep it before the upgrade bug bites? :p
Yeah 200 is far too much, especially as I could get a new mobo and 6300 for about that, oc that and whoop its ass :)
But for around 100inc vat and del if possible im trying to get a dual core (2x1mb version) that will do 300*10
Might we worth holding out for a little longer on the OPterons 939s as AMD has got a big load of cpus to get rid of. Most AMD servers have gone over to AM2 faster than expected which means AMD have got huge pile of 1 series socket 939 cpus sat around doing to naff all. I have seen 144 retail boxed for £90inc vat recently and the prices of 165 & 170 should drop nicely.
But to be honest the C2D 6300 will kick it around the playground a couple times and mash it to pieces.
Rob H
The prices have already dropped, they are now similar to/in line with the Athlon 64/X2 equivalents, for example the Opteron 150 (2.4 Ghz, 1MB cache) is around £95, Opteron 165 (2x 1.8 Ghz, 1MB cache per core) around £110.
Wow, prices have dropped! just found a 165 for £106inc vat and in stock.
Nice price for a dual core Optie, my San Diego 3700 is coming tomorrow and I paid £51inc vat for it! Hope it clocks in rd3200cf-dr mobo.
Rob H
