Technically top of the range PC gfx cards are much better than those in a console. However, because a console has a fixed spec, you can get twice as much from it. So it is very hard to compare.
dont bother comparing, it just doesn't work like that. Id say a x1950 pro is closest in terms of being able to run a game at the same (or a lot better in some cases) graphical level.
