what pc
Permabanned
19 Oct 2007
I need a pc that can do the following. I will be building it and needs to be cheap as possible.
- Using ConvertxtoDVD, make dvd's, dont care how long it takes as long as under 2 hours lol
- USE xp and vista as I need to be MCSE certified and therefore have to use the prior.
- Play quake live
- have coaxial or optical digital out for my dac, and run foobar2k.
Find me something plz, preferable under £250 dont need a monitor, mouse, keyboard, or speakers :D
Is building it a possibility? That will get you better bang for your buck.
Will you need an OS?
EDIT: Just realised you are building (I'm scan reading and missed it)!
Should do?
