What phone on T-Mobile WnW
18 Feb 2006
Change of plan;
Will be opening a new contract with T-Mobile, and getting the Flext 35 WnW Package, so which phone for;
Internet Browsing
Camera
Texting
Would you guys consider?
Looking at the Viewty, and the MDA Touch atm.
N82 has a Xenon flash, so it's better in low light situations.
I prefer the keys on the N95 8GB.
They're both great but the N95 8GB has the bigger screen.
I'd agree with that. N82 takes the photo crown whilst N95-8GB takes the texting and internet crown. That's not to say the N95-8GB takes bad photos, it's just that the N82 will be better in low light situations.
Update, am gonna let the Orange contract run out..and open one on WnW at T-Mobile..so no chance of getting the N82 or N95. But the ones taking my eye are; LG Viewty, 6500 Slide, T-Mobile Sidekick Slide, Samsung G800, and thats about it really.
Any of the above any good?
Any others to look at? Basically any available on the Flext 35 WnW Package really!
Leaning towards the Viewty atm!
MDA touch plus, large screen, and you can surf the net by scrolling and link touching with your finger. Also a stylis is available if needed. Typeing can be done on the screen or on the slide out keys.
Its a really large phone though isnt it?
yep - I wouldnt really call it a phone more of a pda.
Yeah, think the largest i would go is around an N95/Viewty size, because with the keypad down it'll be huge.
May end up being the Viewty, MDA Touch, 6500 Slide, or perhaps the larger side, Vario III or Compact III.
If you are prepared to wait a short while, both orange and T=mobile seem to be on the edge of announcing the replacements to the touch.
google HTC diamond and htc raphael and peruse a few of the results.
If you are prepared to wait a long while, both orange and T=mobile seem to be on the edge of announcing the replacements to the touch.
Fixed - doubt you will see them on those networks this year...
ps3ud0 :cool:
