what phone to get?
18 Aug 2004
midlands
right im getting rather annoyed....
all the phones i have had lately are irritatingly slow :(
i have an n80 at the moment and it continuously crashes, and is slow. before that i had motorola phones, they werent as slow but still they had their times
does anyone know anyphones that arent like this? new ones?
thanks
nickels
thanks
nickels
Thats why i got a nokia today my V3 Was doing my head in :(
I've always been impressed with SE phones. Had a play with k800i and was very impressed with it. I got a p990i to replace a n80 for similar reasons to you, and its miles better. Few issues with low memory, but that should get fixed in firmware updates, otherwise simply a great allround phone/pda
The K800i is a pretty decent phone although when you first select the menu it takes maybe half a second to get the selector moving but after that it is fairly nippy to use and you don't get a memory card with it(it does have somewhere over 60mb built in though). It depends what you want from a phone though as if you need or want PDA features the K800i clearly won't do. :)
