- 10 Sep 2008
- Macclesfield, U.K.
Hi guys,
Im just wondering what size psu i need?
I curently have a 1050w psu but it was very cheap, and my rig wasn't so cheap.
Im going to be adding more stuff to it in the future and im just worried about the cheap psu blowing everything to death, so i wana find out what size i need and then i will get a decent one soon.
My set up is as follows:
AMD Phenom II X4 Quad Core 810 2.6GHz
OCZ Reaper 6GB DDR3 PC3-14400 (1800MHz)
Gigabyte GA-MA790XT-UD4P mobo
Arctic Cooling Freezer Xtreme CPU Cooler
ati 4890 1gb.
3x 200mm fans, 1x 140mm fan.
Dvd drive and 3 HDDs, 1tb and 120Gb x2
Adding a tv card soon.
I plan on adding a 2nd 4890 at some point.
I also plan on adding a coolermaster aqua gate max liquid cooler at som point (its 600w)
I will also want a fan controler and a blueray drive.
Then you've got the keyboard and mouse usb.
SO, what size psu do you think i will need? Ive been told my current one of 1050w is over kill for what i have atm, but with what i plan on adding will a decent 1050w be a good size?
THanks.
ati 4890 1gb.
THanks.
Miles cheaper than i was expecting. Might upgrade sooner then
