What power supply?
2 Sep 2010
Somerset
Considering you budget - this would be a much better bet than that OCZ. This one does come with 4 PCIe 6 pin power cables (2 are actually 6+2 pin).
Edit: Beaten by stulid:) consider this a fervent recommendation.
i had a coolermaster gx 750 before which seems to be in your price range. i cant really suggest anything else, it was cool enough but reviews say it isnt very stable, then i got a tx850 which is great, it might be expensive but its incredibly cool and efficient, are you wanting to go modular ?
Yes I am, My current one is horrible because it isn't modular. I could go up to £100 if there is a better alternative.
To be honest, I wouldn't go with the GX 750. According to this review it is only really a 600W unit and not a particularly great one.
However, the TX 850 is a nice bit of kit - you made a nice upgrade there :)
yeah :) i complained to the company who pre built my pc and they just upgraded me to it free of charge, i think i won :P i was quite scared of the gx750, it used to shut my system off and i had an irregularity on the 12v rail, it showed as 2.4v :S
