where do i get the new core 17 app from biffa ?, cant seem to find it anywhere :/
the one im using at the moment is 7.3.6. is that the right one ?
because i cant find advmethods pn it anywhere neither can i find the other option you gave me.
OK, the application is downloaded by the client depending on what type of project the client thinks that the hardware can handle. You don't manually need to do anything.
First, apologies, the link to the FAQ was incorrect its
here
But basically this is what you want to do:
Right click on the folding icon in the notification area of the taskbar and click on "Advanced Control"
You should get the following screen
Then click on the "Configure" button and the "Identity" tab you get this
Fill in your details and put your passkey here.
Then click on the "Slots" Tab and you'll see something like this
Highlight the gpu slot and then click "Edit" and you will get a screen like this:
Click "Add" and enter the following details
You should end up with it looking like this:
Then you can click "OK" and do the same to the CPU slot, save your way back out of the Configuration to the main screen, and the next time you download a WU you should get the right ones.
