- 27 Dec 2005
- Bristol
Our front space needs some work, and having taken some local inspo we want to go down the not-so-complicated route of a tiled walkway (probably cement tiles) with gravel/stones across the remainder.
A brick or wooden divider and the stoned bit is easy, but what prep would I need to do for the tiled pathway?
Fortunately the entire space is concrete at the moment, BUT it's not entirely flat. I'm assuming it needs to be else tiles that fall on a change in gradient will easily crack. It's not a large space, 1720x880mm, so what would be the best way to even it out? Obviously we want it to have a gradient towards the pavement so anything self-levelling is no good, but I'm sure there's an easy alternative.
Space in question to be tiled... ignore the weeds and mess
