Hi all, I need a printer/scanner (copier not essential ) but unsure wheather to spend about £50 on a cheapie or spend around £100 - 130 and get one that will print high quality photos.
My main use will be to print documents & stuff from the web but it would be nice to be able to do the odd few photos as well - A4 size possibly .Also one that is cheap to run would be good.
So can you recommend a £50 printer/scanner and also a £100 -130 one as well.
Regards.
Regards.
