What printer to go for?
20 May 2006
Hi guys,
We're looking to get a new printer to replace out old Epson 890 :cool:
The printer doesn't need to be anything special, it will mainly be used to print about 5 documents off a month, and the 2 - 4 pictures a year.
The only requirements for the printer will be, it has to be a network printer. Or if there's a cheap enough one, a wireless one would be great!
The wireless network it would be connecting to is encrypted using WPA PSK.
The computer's it will have to work with will be Vista / W7.
Like I say though, if wireless is going to be too unreliable / expensive, wired LAN would be fine.
If I can help it, £100 budget.
I've already had a look at the 'Lexmark X4550' but reviews say if the printer looses power you have to re-configure the entire printer again and re-connect it to the network.
