what processor for 90 watt power supply?
  • Thread starter Thread starter k3v
  • Start date Start date
k3v
k3v
26 Apr 2006
NE Derbyshire
Afternoon,
Im looking at an mini skeleton build for my living room. What are the options processor wise with this case? I will use it to stream stuff to and web browsing but want something that could run windows 7 ideally.
atom build or ION
however potentially you could run a lot more
i would look into the zotac 9300 + a energy efficient celeron of some sorts
my home server idles at ~95W and contains a I7 860 and 6 HDD's + low power gpu and 8GB RAM + high end mobo obviously you couldnt run that on 90W but just highlighting that sometimes power requirements a grossly over exaggerated
atom build or ION
An Atom/ION mobo would be a good choice for a low power build, a system using one tends to use around 40W if I remember correctly.
That wouldnt be the fastest system tho, so the Zotac 9300 would enable you to get a bit more power. Seen these boards running quad core CPUs off tiny power supplies, just make sure you dont get too excessive with overclocking it. If you dont mind spending a bit, something like an E8400 would be great, its dual core and a pretty darn good CPU!
Just dont go for a good graphics card, they tend to be the thing that ramps the power use up, better to stick with the onboard option
Thanks for the replies chaps, i have just got a zotac ion 330 motherboard albeit with a different case. I have windows 7 on it and im just setting it up.
