what program to monitor temps these days? thinking about using AMD
I did try the AMD overdrive Utility but you had to click on different tabs to view info so i currently use CPUID Hardware Monitor that gives me all temps of CPU,GPU,HDD. Also shows RPM of fans and system voltages.
i just noticed (sure it wasnt there last week) that OCUK do a preoverclocked 1055t system. running @ 3.8?
i assume then that a lot if not most of these chips can hit decent clocks?
ps, got coretemp installed. ta :)
