what programming language am i looking for?
20 Oct 2012
west sussex
Hi all.
Im looking to learn to make a bit of code for my dads website, a basic breakdown of what i want......
he sells lampspares/cable/plugs etc.
He wants to have a create your own custom cable section, were the customer can choose 1st the cable type then colour from there it will narrow down the options to choose the plug or if they want an inline switch.
all this to add up a total somewhere to then add to cart.
also to have each product picture by the sidw of the options... or something similar.
im getting more and more confident in HTML and CSS but i think this may be java script / j query? if i know what route to go down i may be able to try and have a crack :D
thanks
Creating the cable selection and option narrowing system could easily be done using html/css/javascript.
I'm not sure on how you plan on the customer paying/order handling, that'll be more involved.
At some stage you will need some code running on the server side. You should check what the hosting provider will allow as that is probably the key limitation.
