alledgely. You can always get one of these plug-in monitor (£15), run intensive benches (Unigine runs GPUs 100%), and see how close you are getting. If it's too much, get a 850W (or whatever you feel comfortable with) and sell the 750W.
I've found that the power requirements for SLI / Crossfire isn't as high as generally expected.
It would be on absolute limits really
For 99% of tasks you would be OK, as long as its a very good 750W, but I would expect you to get crashes under load, 850W is recommended and if OCing then 1000W would be my preferred choice
System specification:
CPU Intel i7 920 @ 4ghz
GPU: 1 X 580 GTX Ocuk STD
watercooling and 1 SSD, and 2 mechanical hard Drives, 6GB Patriot ram @ 1600MHZ
PSU: PC Power & Cooling 750w
Power Consumption:
Desktop Idle: 210w
Prime 95 load: 330w
Full load with Prime & Furmark: 500w
