- 16 Nov 2008
- West Midlands
I have a core i7 rig with 1 470. I will proberly add a second after xmas. I have a corsair HX 750w psu. Will i need a better PSU?
A good 750w model.
Corsair/Antec/XFX/Enermax/Coolermaster silent pro, all good makes.
So i wont need to upgrade my PSU? So often you hear the 400 series need 850w to 1000w of psu power.
the recommended power that Nvdia and AMD set are over exaggerated.
i had a hx 750 when i first had my 470 gtx sli it ran ok but i found as i overclocked it did stress the power supply a bit best off upping to a 850 or 1000w supply
1000w may be overkill but when it comes to the next upgrade he won't have to splash out on another supply
