What PSU?
4 Nov 2004
Norn' Iron'
around the £60 mark
OCZ ModStream 520w ATX2.2 Power Supply (CA-017-OC)
or
FSP Sparkle AX500-A Blue Storm 500W ATX2.0 PSU (CA-005-SK)
ill definately be running:
Motherboard - Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
Processor - Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
HSF - Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
RAM - GeIL 1GB (2x512MB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX21GB6400UDC) (MY-057-GL)
HDD - Seagate Barracuda 7200.10 200GB ST3200820AS SATA-II 8MB Cache - OEM (HD-085-SE)
Graphics Card - BFG GeForce 7950 GT OC 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (GX-034-BG)
***i may end up running 2 7950GTs***
opinions please guys
I would go for the OCZ, but you will probably need a more extreme psu than that for dual 7950s.
i think this is ideal value for money (im getting one tomorrow)
7th case down
but then again if you already have a decent case then you may be best off getting a psu on its own or you could buy the Sontana II and sell the case
