What PSU ?
19 Nov 2006
I need a new PSU , the one I have is just not cutting it
So Ive narrowed it down to these , but if anyone knows of one better , let me know
Thermaltake ToughPower 750W
Corsair HX 620W ATX2.2 Modular
Well I will be ordering one of them in the next hour or so , so any help will be cool
My rig
E6700 , P5N32-E SLI , 2GB Geil Ultra , 8800GTX , 500GB Maxtor , 200GB Seagate , Creative SB X-Fi , so needs to be able to power this better than my antec 550W TruePower does
Thx in advance
Wagsie
To be honest, the 520W Corsair will handle your spec just fine, provided your not planning on SLI.
Edit: Stickroad beat me to it.
But would the 620W be able to go SLI on the slim chance I ever do ?
Thing is I have about £100 to spend but can go a bit more , and just after the best I can get for that
Thx again
Thx again
Yes the Corsair 620 version would be able to power a SLI system.
Going SLI now is really not worth it since most games are not optimized for a SLI configuration.
Going SLI in the future when more games are optimzed for a SLI configuration (that could be a while yet) is still not worthwhile since your GTX will be old tech my friend.
The only reason for going SLI at the moment is becuase your gaming on a 30inch screen if not dont worry about it. :D :D
If the 620W is the best out of the two then I think I'll order that , I would like to think ( hope ) that it will last that bit longer than the 520W
Thx for the speedy replys
