What PSU?
From what I can tell from a quick Google search it's a standard PC case (looks like a Gigabyte 3D Aurora). Dell is the only manufacturer known for using non-standard pinouts on their mobo's ATX connectors so if I had to guess I'd say that it is standard-compliant equipment.
Double check the color coding on the ATX connector you have versus the ATX standard configuration just to be sure.
http://www.formfactors.org/developer/specs/ATX12V_PSDG_2_2_public_br2.pdf Page 36 seems to have the relevant data.
