- 22 Mar 2009
- Cornwall
hi, i got a 9800GTX+ for xmas and to my horror it didnt come with any 6pin PCI-E adaptors and my cheap psu doesnt have one, or even enough molex connectors to use adaptors, as the card requires 2x6pin PCI-E power.
so basically, i dont want to spend a fortune, but i also dont want to buy something that will cause problems.
my system currently is :
but obviously the 9500GT will be swapped out for the 9800GTX+. the other slight problem is the card is a tad long for my case, but i can cut the HDD bracked to make it fit, but if there is a case with a decent psu that isnt too expensive that will fit my 9800GTX+ and atleast 3 3.5" HDDs then would consider that too.
sorry for such a long winded post.
