What PSU...
19 Apr 2009
Hi Guys
My trusty PC&Cooling 1kw psu is showing its age and is getting more and more noisy the more I use my computer. Also its becoming a pain to cable manage with the 20 odd cables that come off it. So im now in the market for a new PSU. Must be 1kw and must have modular cables.
Ive narrowed it down to:
1000W Coolermaster Silent Pro Gold
or the
Corsair HX 1000W
Your views?
Matt
Do you really need a 1Kw PSU, is it for the spec in your sig?
Given your PC&Cooling 1kw is getting on a bit it's safe to assume it's probably delivers around 70 A on the +12 V line.
Since current high end PSU deliver far more of their power on the +12 V you could consider getting a 850 - 900 W PSU, even then that seems way over what you'll need.
Antec High Current Gamer 900W Quad Rail Power Supply is a bargain at £116.99 (71 A on +12 V) As long as it has the connections you need.
(Delta Electronics based OEM)
You have to be running some serious machine to need more power.
