What PSU
4 Jun 2010
Just about to make the order for my watercooling and found 2 psu's that i like,
Corsair HX 750W ATX Modular SLI Compliant Power Supply (CMPSU-750HXUK)
and
Antec High Current Pro 750W Modular '80 Plus Gold' Power Supply
also does anyone know anything about antec's warrenty as it says nothing on ocuk?
which one is better in general?
thanks
Freddie :)
I have only owned corsair PSU's and never antec although I have looked into them, don't know anyhting about their warranty but I'd go with the corsair
Antec Quality 3 Year Limited Warranty
Antec, Inc. warrants its new products to be free from defects resulting from faulty manufacture or faulty components under the following terms and conditions:
I. Warranty Length
For all new Antec products, parts and labor are warranted for three (3) years from the date of purchase, except as noted. Replacement products will be warranted for the remainder of the warranty period or thirty days, whichever is longer. Antec iLuminate LED light products receive a one (1) year warranty and the Basiq 350 (BP350) power supply receives a two (2) year warranty. Products sold as "B" stock or Refurbished stock have their own limited warranty; please click the link above for details.
http://www.antec.com/Believe_it/index.php?page=warranty_info&AQ=AQ3&value=en
The Corsair HX 750 is CWT manufacture, the Antec High Current Pro is Delta Electronics. Top builders are Enermax, Delta, CWT, and of course Seasonic.
I would go against the flow and say Antec (Gold certified), the HX750 is great too. And yeah, you get the extended warranty. I have a HX620 (Seasonic) for a few years, all HX are solid units.
IMO you can't go wrong with either, Corsair having the longer warranty and good customer service, although you will need to RMA to the netherlands (after one year warranty with OcUK).
IIRC, Antec is also Netherlands.
