What PSU?
17 Mar 2012
Hey guys i have been told i need to replace my crappy "850w" PSU, before i get my new GPU this week or next, most likely a 560ti or 560ti 448, and i agree.
My system is:
Mobo: Gigabyte Z68X-UD3P-B3
CPU: i5 2500k with freezer13 Pro cooler (OCed to 4.1ghz)
Ram: 8gb corsair vengeance
Current GPU is: GT210
PSU: 850w
HDD: 750gb
SSD: 128gb
So what PSU do you think i would need to power this?
i have been looking at these but not sure if they are good or not.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-CS&groupid=701&catid=123&subcat=1084
http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-XF&groupid=701&catid=123&subcat=1497
http://www.overclockers.co.uk/showproduct.php?prodid=CA-056-OC
Personally if it was me then I would get a power suply that was a 750w which will give
you plenty of room for your current system and future upgrades as well if you want to
go Sli or anything like that.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-XF
The above is a good PSU if you don't want a modula PSU if you do then have a look
XFX have some good modula PSU's as well.
Also the Corsair PSU that you posted are good as well but again I would probably go for
a 750w
